That's the current WD Utilities I downloaded from the WD site before posting.
Well you got the wrong one
Google something like sn 850x dashboard to see what it looks like. Looks a lot more like the Samsung one.
Ah to me the title of dashboard just sounded like a frontend like Alienware Control Centre so didn't think much more of it as they don't give any extra info lol.
Still not as feature rich as Samsung Magician though![]()
Benchmark stats with history log, drive settings for optimisation/power, one click OP settings, most importantly has built in drive cloning, does it all whilst in Windows and shuts the PC down so you can just swap drives over to the new one. I cam't see such options in WD Dashboard, they reference Acronis via a button link so loks like you need to install Acronis for that stuff which is an inconvenience because as I noted above, having everything under one app is just much better.
WD Dashboard doesn't seem to tell me the firmware of my drive either, and no option to check for firmware updates. The irony here is that Samsung Magician does tell me the firmware of my WD drive![]()
It sounds as though Samsung are either being dismissive of the problem, or have completely missed everything you've told them about the problem.Update, Samsung replied to my email, they said they tested my drive and found no issue, they have formatted the drive and reset it to "defaults" - Not sure what the latter means but according to them 96% health after not even 2 weeks and 2.1TBW is no issue???
I have asked them to respond in writing that confirms such a continued drop in drive health is normal, because no other drive has this issue. If they do not respond with something that actually makes sense, then I will be refunding the drive.
To be honest, the health dropping so soon after buying it wouldn't instil any confidence in me.Currently plugged into USB to clone over, CrystalDisk reports that the firmware is still the same, and the same 94% health that I sent it away on, they have done some writes to it though, I sent it away at just over 2.1TBW, it's now on over 4TBW whilst still being on 94% - So could it be that it has settled maybe? Will find out after cloning completes and I'm booted back up on it I guess.
My drive might be a goner
In the last few days I've experienced lots of issues around not having an image on the monitor either from cold boot or sleep
And then today I woke the pc from sleep and worked fine for 5 minutes and then suddenly screen froze. Did a hard restart and now windows refuses to boot, says the drive is corrupted and can't be repaired
The thing is I don't know if all the hard restarts is what corrupted the drive or the drive itself is just dead, so I don't know if all the issues I'm having is caused directly by the drive or if some other hardware in the PC is the issue
