I wanted to ask this - I have a new combi boiler in my kitchen where the scheduling/timing controls are integrated into the boiler and then a analogue dial thermostat in another room for the temperature. WOuld I just need to replace my thermostat with the Tado smart one and plug in the bridge and off I go?
I've also sent Tado an email so will see what they say.
Yes. My programmer is a separate unit below the boiler but it should be the same concept. I just set the program to constant for heating and let the thermostat do the work.
I was really worried about battery usage but iOS is showing 2% battery usage per day. Well worth it! The graph when you rotate the app shows when the heating has come on.
The way the programs work on tado is you set the time you normally go to sleep and preferred temperature, then you can set multiple times of the day with different temps. The heating will only ever come on if you are in/near the house.
E.g. I have set "sleep" during the week from 11pm to 7am and then a "morning" temp of 18c set for 7am to 9am. After that is is "day" set to 20c. Weekend is different.
