So do I it took me years to get a hold of themNice and love the BSG models.
What are your temps atCustom loop here too, although I'm really not happy with it ATM.
Temps are terrible, unsure whether it's the loop not performing right or just the 5950x running hot.
Once it's all warmed up it idles around 40-50c, gaming/benchmarks fluctuates between 65-90c
All this is at stock with PBO disabled. If PBO is enabled, it hits 90c+ within seconds then starts to throttle.
GPU around 45-48c & water is around 32-38c when gaming for a couple of hours depends on the fans profile I use at the time.
Custom loop for me
you won't break it that fast but it'll limit your performance, best you can do just enable ECO mode in BIOS or via Ryzen Master, it'll turn your 5800X into 65W TDP CPU which is ok for the cooler you haveWould a wraith prism be able to handle a 5800X in the interim for some gaming until I decide what cooler to go with?
They are quality AIO's, used the 360 and now 420 here.I made a slight change to the BIOS for my Artic Freezer II 280, just upped the minimum RPM a wee bit and booted into windows, its still quiet but temps at idle and while watching youtube have dropped from around 41c minimum to around 35c minimum.
Seriously impressed with this AIO![]()
My only small gripe is i wish you could control the pump RPM without having to increase fan speed to do so.
They could, but only downside is the wire is very short so you'd need several extension cables, might get a little untidy but possible i suppose.That would be nice but if we could do that then id also like to see temp monitoring of the water like i could on my corsair. I did not pay much attention to connectors on the fans but did notice a plug daisy chaining them into the AIO?, perhaps they could be unplugged from it and connected to another mobo header?
That's a good idea, though I am still not sure if the cables will be long enough to reach all fan headers. I suppose you probably run all three off one fan header though with a splitter.Or alternatively, you can buy the Artic fans separately with the normal cable lengths or any 140mm fans you prefer and swap them out with the pre fitted versions, then use whatever headers you want on the mobo to control them![]()
something wrong with your loop alright, probably the cpu block fottibg or contact.
I can get better temps than that with a $25 air cooler so if you can't do better with water something is very wrong
