been lurking here a few months, and was put off by some of the fan noise problems on the AW3423DW,
looking at going for the AW3423DWF, coming from a LG 34GK950F-B, anyone else gone that route, where your expectations met ?
and are there any issues on this one to be aware of ? and will it work ok with an Nvidea card ?
really struggle finding monitor's to replace the LG 34GK950F-B, its an amazing monitor, but having owned an LG OLED tv, i know they are in different league, so really fancy this,
or maybe i should just stay with the LG 34GK950F-B ? paid similar money as these for it originally lol
I have an AW3423DWF, came from an AW3821DW, and use it with NVIDIA.
I have no problems at all. It's great monitor and works perfectly. No fan noise. I must admit, however, that I have "old" hearing so I can't tell you whether it has coil noise - I wouldn't hear it even if it does.
I use an app called AutoActions to switch to HDR mode when I play a game, and everything works great.
There are no problems using HDR except when the game is set to Fullscreen mode. Tabbing out can cause the screen to go black so I run the games in Borderless Fullscreen Window, and it works perfectly. I have no idea whether the issue is caused by the monitor or Windows or the game, I just accept it as a quirk that is easily bypassed. I have heard of this sort of thing before with other monitors, that tabbing out of games in Fullscreen is not a wise thing to do so perhaps it is a Windows issue.
The colour quality is better than the finest LCD monitor. It is certainly better than the AW3821DW, and that's a really good monitor. The only annoying issue is the lack of support for the sub-pixel layout which can cause fringing around text. This is amplified by my PC glasses, which doesn't help!!! It's also not really noticeable if you use Windows in Light Mode. Hopefully Microsoft will fix this one day. There is a "sort of" fix out there but it doesn't work for dual monitors.
The four hour pixel refresh is a slight annoyance, but I see it as the same as a pet - they need food breaks or they stop working!
In all, I would buy the monitor again in a flash. The colour and particularly the contrast and speed are just spectacular. It made me realise that HDR on an LCD is a con - it's just brighter, it's not better. On the AW3423DWF it's better. Way better.
Dell are currently looking at some inconsistencies with the HDR modes in the AW3423DWF, but honestly I don't notice anything wrong. Maybe that's the particular mode I use. I am sure at some point there will be a firmware update, luckily that's really easy with the F version.
Anyway, the AW3423DWF was cheaper than the AW3821DW but in my mind it is more than a worthy replacement.
