So I noticed this problem a few weeks ago and ran a panel refresh and it did not make any difference... I've just ran another panel refresh and it actually seems to have improved it to the point where it is now barely noticeable... I think that the refresh maybe did not run properly last time I used it.
I don't know if this is related but... The power light is supposed to flash red when doing a panel refresh and green when it is doing a pixel refresh, is that right? I am 99% sure it was doing that before. Because I've just done both and it just kept cycling colours like it does when on. Going to give the monitor a power cycle and see if that helps the LED situation.
Image of it after refresh... You can still see some of the discolouration on the left hand side but it is nowhere near as noticeable.
You can't miss a panel refresh cus it asks you before it does it! But yes, the power light flashes while its going on and then once it's finished it switches off.
It looked like a nature type background! If it is that then change the wallpaper more often. I think I have mine on "every 10 minutes".
