This happened to my first DWF, it seems the tape holding the protective foam over the screen had come unstuck from the frame and stuck to the screen leaving an uncleanable mark, i raised it straight away and received a replacement within a few day, they collected the faulty one. The new one did not suffer the same issue.After comparing the Apr2022 and Dec2022 manufactured aw3423dw, only difference in packaging is they now include a micro fibre cloth - the bubble wrap around the screen still leaves marks after all these months they haven't fixed it, they just give you a cloth now and tell you to clean the screen. Calibration report looks pretty similiar. The Dec2022 model is on firmware MOB103
I tried distilled water to clean using the supplied cloth and then Isopropyl alcohol (at direction of dell support) and neither did anything to resolve the issue.
I wonder if the calibration is done after its been initially packaged so someone is removing this and then reattaching post calibration leading to some instances of screen surface damage?
