Enable HDR only for games/movies, not for anything else. Creator mode for desktop/normal use otherwise, unless you like the oversaturated colours typical of Samsung OLED of course. Creator mode is the most accurate for colours too.
Does anyone here with AW3423DWF has recommended settings?
Edit
Anyone managed to run 10bit 165hz by forcing the panel via custom resolution utility?
I have heard its successful
You may have a CPU bottleneck but only at really high FPS the monitor can't use. Just cap it to 165hz and don't worry about it.What's everyone's experience using a 4090 at this res 3440x1440 I'm pairing with my 5800X3D. Normally I game at 4K on my 55" LG CX. Will I be ok or bottle necked cpu wise?
Based on one persons experience I can comfortably say Yes on behalf of ocukAm I the only one who limits to 100FPS in an attempt to stop so much heat pouring out of my PC and into the room in this hot weather?
Depending on the game / system the 100fps target might not get hit so it’s pretty much pegged anywayHave you actually measured the temperature difference in your room between limiting it and not?
Initially used them, they work fine and I doubt I’d replace them if I didn’t need to but I needed a 4m long display lead…For those who purchased the Dell, have you used the leads which came packaged or bought another. Thanks.
Yes I did. No probs here on both hdmi and DP.For those who purchased the Dell, have you used the leads which came packaged or bought another. Thanks.
Very nice, please upload and post a link to it!!Got a keyboard in for review and one of the photos going up I really liked how it makes the screen look like peering through a window:
Sorry, I meant desktop paperStill drafting it, will be a few days![]()
