This can be had for under £700 with varies discount codes... Bargain![]()
Care to share the codes.This can be had for under £700 with varies discount codes... Bargain![]()
It'll be an upgrade in everything bar a bit on text clarity, your choice.Rocking a LG 32GP850-B atm which is well received but got that upgrade itch
Me neither and I use mine constantly for my IT work..Must admit the text has not bothered me at all. Sure if you go digging for the issue you will find it.
My previous main monitor was LG 27Gp950 4k so I expected it would be much worse.
Yes, the text clarity is still an issue. I am really surprised that Microsoft still hasn't done anything about it. It is so easy to fix, if you are a company like Microsoft. There is a solution, by the way, it's called Mactype. How to set it up is documented in the forums here. The only problem with it is that doesn't work with dual monitors, which, unfortunately, I have. That's why we really need Microsoft to get moving and get it sorted!!
No, but it's as good as we are going to get until Microsoft and others recognised OLED.MacType is not a real solution
I think it's a Marmite thing. You either don't notice it at all, or it drives you mad. Personally, I use two monitors, so I can use a standard monitor for normal stuff.
There's a similar setting in the AMD software under Colour control called 'Saturation' iircWhat's the best way to increase colour depth when using an AMD card? I'm finding the colours are looking a little bit washed out and on Nvidia I would adjust this with the Digital Vibrance option in NCP.
Another question; should Eco Mode be enabled for the pixel refresh facility to work automatically?
