How do you measure this?I wonder what Dell did to drop the latency in the new firmware?
I mean I can't even feel the difference but tech speaking at full 175hz refresh the monitor has 50% lower input latency now than on the previous firmware and that's huge
They did - rtings has tested and proven the difference.I wonder what Dell did to drop the latency in the new firmware?
yep, it happens randomlyGoing to be raising a ticket with Dell as I've been having power issues with my 34" QD-OLED last few weeks.
It seems to randomly struggle to power on after being on standby, not sure why. The only way I'm able to get it turn on again is unplug the power and reconnect.
Today it's been a blinking purple light, the other day it was just a blinking white light.
Will see what they say on support tomorrow morning but rather they just replace it.
Anyone had this issue?
Any way to update firmware on an original one of these? Think I'm on MB01.
Depends how cheap, iirc it's the 'worst' QD OLED UW but that may have changed with any recent fw updates. Def do your research first.Looking at getting the Msi MEG 342C qd-oled, as it’s currently on offer.
Thank you for this, just updated to latest FW so will monitor how it behaves, if still issues then will RMA.With an Nvidia GPU you can: https://www.dell.com/support/home/e...phf&oscode=wt64a&productcode=aw3423dw-monitor
Arguably Samsung G8 with its mini ports and horrendous CS is a worse buy than MSI. That said, I would just buy Alienware, smooth warranty process is super important on these monitors.Depends how cheap, iirc it's the 'worst' QD OLED UW but that may have changed with any recent fw updates. Def do your research first.
Can't remember which one I was on but I've not done any FW update until now, bought the monitor last november.If you had a monitor with the early MB01 firmware it fixes the issue with the monitor turning off after a pixel refresh which was really annoying.
Hopefully Dell take note for next gen QD-OLED, because LG have just announced new OLED monitors tat support variable res and refresh rates, one sporting 480Hz at 1080p etc:
LG Tease Exciting New Range of OLED Monitors for CES 2024 - TFTCentral
LG Tease Exciting New Range of OLED Monitors for CES 2024 including 4K@240Hz and 1080p@480Hz capable 32" display!tftcentral.co.uk
