I put on my robe and wizard hat...
Go on...
Pwnt!I have yet to hit 40, but not far off. Sad as it should be 30![]()
Pwnt!
Everyone says I look nearly half my age![]()
Male (I like female TitsNAss) and Greater London![]()
Said like a true stink face![]()
Clearly you've not seen my work online then, also been here since 2002, a time when putting system specs in sigs was actually coolDon't pretend you ever go outside. You have far too many posts for that.
Same... not far off now.. depressing really![]()
Clearly you've not seen my work online then, also been here since 2002, a time when putting system specs in sigs was actually cool![]()
Wait until you're a couple of years away from seventy...now that's ******* depressing!![]()
Hello There....also been here since 2002
I was, I am a pre-nuke survivorHello There....
But were you a member of the OG forums pre-2002? Back when we used Hexus Trust for the MM![]()
We’re only just getting 32” 4K OLEDs next year so it’s probably somewhere in the pipeline if demand is high enough.Serious question guys
Is there a technical reason why we don't yet have any high PPI 21:9 monitors?
Why can't manufacturers make a 21:9 34 inch with a resolution of 5160x2160. 5160x2160 is the natural next step from 3440x2160 as it's 50% more pixels on each axis and would create a high ppi screen
They are coming. He even posted about it some time ago himself![]()
