at the minute it is being painted black and then a coat of laquer possibly to give it a bit of shinepics as soon as it arrives on my door
Has anybody modded the Eclipse 62 to have a mesh grill side rather than the window? If so, any pics/tips?
i was looking at meshing a window on the side of mine but i thought it might make a dust issue.
tips on it thou - fine tooth jigsaw to cut the mesh or a handsaw, jigsaw and file to cut and smooth window design, and then either black hex bolts or No more nails to secure it![]()
The Akasa 62 looks awesome with the paxmate and watercooling. I wonder if I'll be able to score one in the MM![]()
hmm just looked at how expensive they are.
TBH I am considering the Lian Li PC7 as well. I won't have money for a week or two so I suppose I'll just scout and take whatever deal I can find.
What you saying... They are as "cheap as chips" don't skimp on a good case...
maybe i'll have to stretch my budget.![]()
The PC7 is a very good case but it's not a great case like the Eclipse. It feels very cramped to work on compared with the Eclipse.hmm just looked at how expensive they are.
Thought I'd update mine-
Spot the new tubing...
not the best pic in the world, but I'm finding the eclipse a bit tight for space
