What memory are you using? and what speeds you going forI'm about 3 reboots away from putting my old 680i board back in, I can't seem to get this one Prime stable at anything but stock speeds and memory underclocked.
whats the best chipset drivers for this?
(new to Intel chipsets)
also, what 4gb ram do you reccomend for this board?
Using the 602 bios and I still cant run the ram at stock 1066 (Corsair XMS2 or Crucial Ballistix) when the board is overclocked. Still can't get past 450fsb.
the reaper only comes in 2x1gb sets, i thought it was not good for overclocking to fully populate your ram slots?
Hi, Andyr, I've put in your settings and running a prime max stress, my core temps are hitting 79c on one of them. Do you think this is normal?
Thanks...
ChrisC
Bit high but if you have two gfx's in your loop then they will kick out a lot of heat into your water , are all cores within say 5 degrees of each other?
is that using core temp btw
I can't even run my ram at stock 1066 without lockups either, even with processor at stock.
