Nah I wouldn't worry about it. The four drives at the front of mine stay cool (2x36gb Raptors in RAID0 in the upper two slots, and a 300gb Maxtor and an 80gb Barracuda in the lower two slots) and still let the air through to the rest of the case.
I think I have finalised my build and this is the case...however, one quick thought, does it accommodate the Enermax Galaxy 850W EGX850EWL ATX2.2 Modular PSU ?
Yes it does...![]()
Feels like a long often tortuous journey has ended.Woot....Feels like a long often tortuous journey has ended.
not the best pic in the world, but I'm finding the eclipse a bit tight for space
s754 setup
1gb ram
2x 500gb samsung drives (at front)
2x 160gb samsung drives (above cpu)
1x 80gb maxtor drive in 5.25 suspended to silence it.
fans are a bit loud at 5v, so is the AC on the x800xt, need some new cooling stuff.
waiting for soundcard and tv tuners, might also add some more sata ports as I'm out of space bar 1 ide channel.
It will fit easy but you have to cut the case where the psu's bottom fan is.If you don't do this the case blocks half of the 130mm underside psu fan.I have allready cut mine & I'll try to post a picture of my Eclipse with the Galaxy installed when i get home tonight.
(also in my project log with a bit more detail)
graphics, 4 + 24 pin power plugs will be hidden next weekend
little update to my case(also in my project log with a bit more detail)
incase you cant notice
motherboard tray has been sprayed black and glossed, sata cables been changed to go with my themegraphics, 4 + 24 pin power plugs will be hidden next weekend
Where did you get those red glossy SATA cables![]()
think it was something stupid like £6 for 3 1ft long cablesoff a well known auction sitethink it was something stupid like £6 for 3 1ft long cables
