Oh yeah, much betterJust clicked it once backwards, do you know if its goes back anymore? Dont wont to over do it.
Can anyone let me know if you can tilt it more than once?
Its on-site if you register with digimate, although they don't currently have this monitor as an option for registering which is **** so can't register and its supposed to be registered within 2 weeksI think it should be listed as 3 year collect and repair tbh. I know that's what other people use. Onsite suggests the repair is done onsite ie a swapout. If it was a desktop PC onsite would assume a person comes out to fix it. Not a return to base.
It's not onsite and it's not return to base.
. Anyone else found this or just me? I have emailed digimate but not got a reply yet, anychance of getting them to sort this out Gibbo?Its on-site if you register with digimate, although they don't currently have this monitor as an option for registering which is **** so can't register and its supposed to be registered within 2 weeks. Anyone else found this or just me? I have emailed digimate but not got a reply yet, anychance of getting them to sort this out Gibbo?
My main gripe with this monitor is that the resolution is far too high. The text is difficult to see, unless you sit quite close or have good eyes. My eyesight isnt bad, but I find it a lot less fatiguing if the text is easily readable - being of good size helps in this department.
EDIT: just to add, this monitor throws up A LOT of heat, from the back. In fact, it generates more heat than my CRT, though I'm sure it uses less power.
) and I can't say I have a problem with the resolution being too high, but then I used 1280x1024 when I had a 17" CRT so I am probably used to it.... I used 1280x1024 when I had a 17" CRT so I am probably used to it.
Go into your browser and manually change the font size to suite your taste.
Or press CTRL and mouse wheel up or down to alter the text size on the screen.
Rgr that Keithcun, only prob is that this method is not permanent (you got to keep doing it every time you start IE), but a good tool/tip never the less as it allows on the fly adjustment for various sites if needed.
I use Firefox web browser and have set the font size set to 20. which is fine for m' old eyes.
How do you set it to 20, in FF is just has text size increase/decrease.
Anyone played about with the tilt on it?
Tools > Options > Content from the browser toolbar.
Morning all,
Just got mine in now and testing to see if everything is ok. So far, I have found a pixel stuck on blue, so I'm seeing if it can be fixed with UDPixel. Has anyone got any tips for fixing these?
Are many others getting dead pixels? Are these panels that didn't quite make the grade for Dell 24's?
If you download UDPixel and carefully scan the screen using each different colour, you might see a pixel stuck on a particular colour. It takes some careful looking to find one, but once you know where it is you keep being drawn to it.![]()
Nah will give it ago. Might be best if I dont then!Nah will give it ago.
Have you tilted your screen at all?
