Probably depends on ram type to a degree , but i find 0903 stable , clocks a little bit higher for me aswellso what't the concensus on the best Bios version to use for this board now?
What BIOS are these currently shipping with?
, SO i left it at 2.8 for him, i noticed though, from 1.375volts in BIOS, it was showing as only 1.1 i think it was in CPU-Z.Built PC for my friend today with a Maximus Formula, board seems good, updated to the latest bios, then got to start overclocking, didnt get much chance though as my friend was worried about me breaking it lol, SO i left it at 2.8 for him, i noticed though, from 1.375volts in BIOS, it was showing as only 1.1 i think it was in CPU-Z.
Nope speedstep is disabled, something definately isnt right, as he just told me over MSN that the CPU still isnt stable, and its only at 2.8you sure it wasnt "speedstepped" voltage and cpu speed it was showing
Its at 1.375 in the BIOS, thats what im confused aboutHi, core voltage is too low...
Chris
Okay I am all set up, I have been ruunning at 3.5 GHZ with the crazy auto level up option in 903 bios.
I decided it was time to get up to 3.6 which was alway my aim so I have gone into the bios to chage the FSB to 400. However when press enter to chage it it won't let me. Also when I try to change the cpu ratio control it won't let me.
Any ideas?
