Yup, went from an m1710 to this. Obliterates it in every factor apart from battery life. (got my 1525 for that, though)Hi, I currently have an M1710 (with 7950GTX) - I'm just wondering has anyone gone from one of these to a 1730 with 8800GTX and was the upgrade worth it?
I have priced a 1730 with 2.5Ghz, 4GB and dual 8800's for around 2100 euro or 1700 stg
Drools at prospect of gaming at 1900x1200Battery life isn't an issue - I see it functioning more as a UPS in the case of a power cut. Thanks, certainly food for thought....
You can watch the battery metre go down like a ton of bricks![]()
The driver support for 64 bit is a total joke. hacked drivers were really unstable but the same drivers on 32 bit are ok
Does this mean you recommend avoiding 64-bit Vista?
Are all of the 4GB of RAM used in a 32-bit operating system?
Is it worth going for 64-bit Vista as opposed to 32-bit Vista (are there any limitations with 64-bit)?
Thanks.
There must be something very wrong on your set-up, my vista 64 install has gone without a single problem. Currently running the 175.12's and they are rock solid as were the previous 4 driver versions I tried.The driver support for 64 bit is a total joke. hacked drivers were really unstable but the same drivers on 32 bit are ok
No, much of it will go AWOL due to the max addressable 4gb and the video cards, etc eating into the ram. 64 bit is the only way to go.
I would advise against 32 bit with such a machine, 4gb makes gaming and general use much better than 2gb and/or a 32 bit os.
