have you got C1E & EIST enabled?Cool.
Well I just set 1.5575 in bios and in windows Cpu-Z shows 1.4v but oddly under prime it went up to 1.48, I thought it was meant to droop?
btw which exact CPU do you have as I seem to have missed that?
Its loading at 55 C at 3.6Ghz.
Its already beating my DS3 as I could only get 3.5 stable with that.
no, but that is why you are seeing such a large voltage drop when idle & the vcore then increasing when put under load.Yes they are still enabled, should give me any problems with it on should it?
Wonder if anywhere accepts memory back if it dosent work in the motherboard??? cos Im really temped to get another 4gb in my system while prices are low. Cos in a year or so when I need another 4gb the prices will be like ddr1 memory... What do you think I sud do guys?
Thanks Cob, when I get the mem, I will stick it in to see if it will just work, then if not I will up the volts. Whats is the MCH anyway?
MCH = NB, ICH = SB.
Looking for 430 fsb min really.Anyone got a Q9300/Q9450 with stock board cooling?
I've currently on 405 * 7.5x (3.05ghz).
CPU: 1.28V
MCH: 1.33V
CPU VTT: 1.18V
ICHIO: 1.5V
ICH: 1.05V
GTLREF: 67%
Anyone help me out with some settings to push the fsb further as i cant get 415 stable with current settingsLooking for 430 fsb min really.
