 - 17 Apr 2007
 - stat city
Chest looking thick as hell, wardie.
Thanks.
My chest is one of my stronger parts. I'm not big though YET, i've just got decent shape/proportions![]()
I'm natural and smaller framed (with ridiculous genetics) so i'll never get to a stupid size anyways.
Thanks, means a lot. Although I don't have motivation issues it gives you a little bit more when you know you're heading the right way.
I basically want to keep the shape i've got, just bigger!
I'm natural and smaller framed so i'll never get to a stupid size anyways.
Keep that v-taper, it will get the mung (i cannot believe i am using that word!).
I just had to google "mung" and I don't like what I just read!!![]()
  Besides, what's wrong with Queen?!
 And lastly (ok so it's 3 things) that's how you do deadlifts!!!
I'd say it actually dangerous to lower the bar slowly on deadlifts once you get to a certain weight. From a bodybuilding point of view it can be usefull to lower the weight slowly using a moderate weight allowing higher reps to try and stimulate maximum hypertrophy.With deadlifts, does the full movement not consist of the lift AND the lowering down of the weight? Surely, as the video is showing the guy only lifting the weight (then dropping it) and not lowering it, he is doing half a dead lift?
Another point of note is gym etiquette - is it seen as "ok" to simply let such a heavy weight drop down to the floor like that?
Sorry Freefaller, I'm not picking on your video, I genuinely want to the answers to my questions.
 Shame I didn't get the 205kg on vid, but it wasn't much different, but definitely more of a struggle.
 I really hate that.On DLs unless you're using relatively light weights say around 100kg...
At least I didn't just let it go or throw it down like some clowns at my gym do.
 On light DLs I do them in a more "rep" fashion so that they just kiss the floor and then I bring them back up again. However for DLs you don't REALLY need to do that
) the negative part of the rep is just as important performed as part of the rep keeping a good tempo. There's no need for tempo on DLs
