Thanks for the pics.... it does look great value for money.. if only I can keep my sensible head on and not spend £500 on a lcd tv.....
A 32" 1080P TV will blow you away more than the 28" Hanns-G would.
Don't worry about 1920x1080 being stretched to a 32", I used to use a 37" as my main monitor and it looked stunning with 1:1 Pixel.
So you reckon a 24" hazro updated panel and a 32inch 1080p LCDTV would fair a better soloution for quality?
the second one looks pretty bad
who then said that 'it may had come open and had to be resealed'. But upon further inspection it definately has been opened and resealed.mine was fully sealed, have you got any dead pixels etc?
Just received my Hanns G at work.
The box has been opened and resealed, also the Hanns G Inspected sticker has been cut and a new one stuck over the top.
Not happy.
Been in touch with sales who then told me to ring tech supportwho then said that 'it may had come open and had to be resealed'. But upon further inspection it definately has been opened and resealed.
Sent webnote and waiting for reply
It concerns me that it has been opened and resealed as this would indicate B grade or a return, has anyone elses box been resealed?
Don't know if I should to ask for a swap for an unopened one, or wether to take it home and check the contents and power up the thing?
