Any one tried PIP ?
I can get the PIP box up but it wont let me change the source for the PIP. It stays at video.
Yes, same here. I wondered if it would only work on other sources if something were plugged in...
Jim
Reset the OSD to default then drop contrast to around 46-50 and brightness to a comfortable level to your eyes. Job done!
Found the manual. Nothing inparticular said about PIP
What ive found if I force the main input to video then the PIP default input is no longer video and and you can cycle through the inputs fine.
Looks like another bug in the menu![]()
I think maybe that's the expected behaviour. ISTR reading somewhere (above?) that Hazro are using the same display controller as Dell, and IIRC Dell use Genesis devices. Looks like they only have one device that matches the spec for this monitor; the HDCP-FLI5962.
Hi all, my first post here, i received my hz24wi today. Overall it's an excellent monitor, really sharp image and good colours. Compared to the digimate 24" i tried first (AMVA panel) the image quality is amazing, virtually as good as my old NEC diamondtron CRT.
Oh, hang on, I might have that wrong - there are some more monitor driver chips listed in with the flat panel tv controllers. eg FLI8548H could be what Dell are using for the 2408WFP. It has more flexible PIP options (and PBP), and audio stuff too. If that's what's Hazro have used as well you might be right Mick.
Hmm, are these likely to have field-upgradable firmware...?
Jim
ooh, didn't try that, will give it a quick go now, hang on.
edit: nope, that worked fine as well, sorry!
I have absolutely zero banding on my 26Wi and have not adjusted any of the settings so far. At default I am very happy with mine. I'll probably fine tune things in time though, maybe buy a callibration tool.
