) and I've lowered my CPU to 10x300 then 10x250 to get different memory dividers. So far I've booted to Vista (and done a blend test to push the RAM) at the following (note my RAM sticker rates 4,4,4,15 between 2.1 and 2.2 volts):
RAM now running stable at 550Mhz (1100Mhz DDR) at 5,5,5,15 2.14v.... It just keeps going. The heatpipes are just starting to feel warm on its heatsinks, so I guess it's got room in it yet! I don't think I need to carry on going? Surely 1100Mhz on 800Mhz RAM is more than enough of an overclock? I can't see myself needing more than 550Mhz FSB on the mobo at 10x multi once I start pushing the CPU = win?
Got any screenies for that clock? The way your post was written "mem speed etc -".... then a gap, looked like there was meant to be a pic?? (EDIT - n/m, just got the email notification with the pic link, it's not loading inside the forum for some reason).
Not my hardware - that has bags of room left yet... It's my lack of knowledge (n00b alert)
Could someone (Big.Wayne? VTR?) please check my new thread, if you would be so kind, to save me derailing this CLOCKS thread any further? My help thread. Much obliged
Not yet, the weekend if I've got time
What voltages should I need on the NB for what FSB's? What's the highest 24/7 NB voltage for stock cooling?
I know that anything up to 400mhz i don't have to touch any of the motherboard voltages. For 450mhz (with a Q6600) i had 1.42v set for the NB. I think it was 1.55v for 520mhz when i got a E8500 to 4.5Ghz.
Would you please take a quick look at my problem thread, linked just above your post?
Hi Rainmaker,RAM now running stable at 550Mhz (1100Mhz DDR) at 5,5,5,15 2.14v
) on the FSB-Hole. This move is a little tricky to perform at first and requires great patience but basically involved setting the FSB 5MHz-10MHz *beyond* where you think the FSB-Wall/Hole begins and try again to boot the PC or carry on your stability testing. You may need to do this 4 or 5 times as u gradually leapfrog to a higher and higher FSB frequency. Obviously while testing for an FSB-Hole it would be best to have the CPU's divider set to minimum (x6) to take it out the trouble-shooting equation and same for the memory, set sticks to a relaxed set of timings and make sure they have enough juice (vDimm)
snipped helpful stuff![]()
I have CPU-Z shots in that thread, showing my already successful 6x510 run at 1:1 and auto voltages on the chipset
6x520 won't boot (explained in my other thread), that's my "wall" so far. I need help working out what to do next if you don't mind checking out that thread please mate?
Thanks again for your help!Rainmaker said:
lo this is my first overclock does all look ok.the volage core on cpuz is wrong in my bios it set to 1.275.only up to 4.00ghz feels fast at that
Nice speeds there kitfit1!5.1ghz is completely 3d stable as well, which is why i'm posting it at the
