The Lian Li Armorsuit PC-P60B's main advantage is the *3* 120mm fans built into the door, so much easier to clean when I do my case maintenance. The Akasa has one major flaw thet I have found with its front 120mm fan assembly, to clean the front fan and filter as you know both side panels have to be removed, then the front bezel has to be removed which with shovel sized hands I did find difficult trying to press the clips in to release the panel. With the introduction of the Omega I was hoping they were going to improve the ease of access to the front fan, mabey make the whole door on a hinge with the fan behind without having to remove every panel for cleaning... Roll on the Akasa Eclipse V5
Thinking of buying the Akasa Omega.
I was wondering about the PaxMate2 kit. I'm not 100% convinced it would make a huge difference to the noises coming from the case. However I do like how the material looks good on the bottom of the case as I've seen in quite a few photos from this thread.
