It seems that no one has names to go with the manufacturer codes yet as seen in this thread. However, LG and Samsung were among the higher quality panels for the previous MBPs.
Ok thanks for the info
Nice, thanks.Try this:
http://att.macrumors.com/attachment.php?attachmentid=141541&d=1225060923
Thats been professionally calibrated.
Drop it into Macintosh HD/Library/ColorSync/Profiles/Displays and then obviously select it from System Preferences/Displays/Colors.
Note that the config is supposed to be for a 9C84 panel.
There's an easy fix for the loose battery cover, have a look on macrumors forums.
just the few that have the problem making a lot of noise?
Thats not good, delivered means its reached its final destination.
That can't be good. Give them a ring?
