yeah pretty impressed with this game. i just hate how i have to run around in the underground for 30 years to get from A to B![]()
That'd be it, then. I totally missed all of that. The first time I properly encountered the Brotherhood of Steel was after escorting Dr. Li etc out of the Jefferson Memorial, by which point I think I'd already hit the level cap. I played basically the whole game unable to equip power armor. And I never even saw a Super Mutant Behemoth, either![]()
Isn't there a mod or a way to edit the running speed?
I find it just a bit too slow, yesterday I had to go to Fort Constantine and it took me ages to get there as I never visited that part of the map![]()
Yeh I agree, they should have made certain places inaccessible until you got the 'key' or whatever from a main quest line. I was exploring the map and doing freeform quests and stumbled into vault 112 - I had no idea it was part of the main quest and happily wandered in, only to find that I'd missed a huge chunk of storyline when I got out again![]()
So it would be best to do the main quests and stop before the last one and then do the sidequests and exploring?I was exploring the map and doing freeform quests and stumbled into vault 112 - I had no idea it was part of the main quest and happily wandered in, only to find that I'd missed a huge chunk of storyline when I got out again![]()
But that takes away from the immersion within the game - if you can't do a) until you've done b) etc. I like that you can go anywhere and "stumble" upon a part of another quest.
What is the last quest. Just so I know when to go exploring before the end.
i just mix quest and main story
The last quest is called 'Take it back!', and when you get to it, it will be quite a build up and so you should be able to tell something big is going to happen.
