- 20 Jan 2004
- Fife
No utility will report the igp clock speed correctly.My GPU seems to be running at 400Mhz by default anyway.
That's because it's running at 400MHz anyway so would make zero difference.
I was thinking of maybe getting this. Or the Asus X59GL for just £100 more. I'll probs wait though because i don't actually need it.. just want it lol.
Many thanks for the MaxDVMT GPU memory tip, well worth doing for those with 2GB.
The GPU is underclocked and so GMABooster does slightly improve performance in benchmarks, but not by a huge amount and so may not actually be that noticeable in real apps. Here are some benchmarks I found (not mine):
http://img134.imageshack.us/img134/330/gputest1qj8.th.jpg[IMG][/URL][/QUOTE]
Almost interestingly, I've just run 3DMark03, and scored slightly higher than both of those scores without tweaking a thing. I got 713 straight off.
Just a friendly FYI mate, you can only have 4 lines of text in your sig, and your last line has just gone over onto a 5th.
Any chance you could run again after using GMABooster set to 400MHz? Would save me having to try installing 3DMark03 on mine (not sure if it would under Windows 7).
. Results to follow!
