so what/ how many things in total are connected
Like 5, will check properly tomorrow but I gotta take shower + shave + do some homework
Cya and thanks for the help
I would remove that competitor link if i was you...
Something like this would be fine for the >10meg connections.
Are you the only wireless client on the network?
Is it impossible to run a wire from your parents bedroom to your computer?
Can you plug the modem into the master socket and test it from your brothers PC?
Then you will know what your potential sync speed is.
Also try the router plugged into the test socket (behind the faceplate, bare in mind removing the faceplate 'should' cut off all the other phone ports in the house...)
Right, this isnt that hard.
This is what your like atm?
Phone line --- Modem Router --- Integrated 4 port switch --- Your Comp
--- Wireless --- Your Brothers computer
If yes, the its simple:
Phone line --- Modem Router --- Integrated 4 port switch --- No computers plugged in.
--- Your Computer
Yeah, you only need to have the power and telephone cables plugged into a wireless router.
Your computers then connect to the router wirelessly.
Before you move the router, make a note of the WEP/WPA passkey.
It might be written on the bottom of the modem...
You will need that when connecting your computer to the router.
It should be fine, i would set up the wireless stick and connect to the router wirelessly before moving the modem.
Means you can see your connection instantly
When you do it can you print screen your line stats?
Cheers![]()
