- 5 Jun 2003
- Falling...
FF I knew I should have added all this in my original post there.
I did post my progress in the gym thread some time ago but looking through I think that might have been the old archived thread and I cant even find it in there.
EDIT: Found my old post here.... 2 years agodidn't realise it was that long! 21lb in 10months. ~50lb in about 2years total IIRC. Today I'm not much different to how I look there to be honest, just a little softer around the waist and ass
What I ate today, a typical day:
Brekkie: Oats + Water, 3xBananas, Wholegrain cereal + SS Milk (if Im still hungry)
Brunch: 74g Tuna + Wholegrain Cob
Lunch: 74g Tuna + Chilli Con Carne + LG Rice
Afternoon: Bag of mixed nuts + Banana
Evening Meal: Chicken Breast, LG Rice, Sweetcorn, Broccolli, boiled Potatoes
Late night Snack: 74g Tuna
Workout (admittedly probably basic by some standards)
Mon: 20min bike Max effort. (3x10) BB bench, Fly, Dips, Mil Press, Lat Raises. 100 situps
Wed: 20min bike max effort. (3x10) Squats, Ham Curls, Leg Press, Calf Raise. 100 situps
Thur: 30min Jog
Fri: 20min bike max effort. (3x10) Deadlifts, Wide Pullups, BOR, Shrugs, Curls. 100 Sit ups
The bike and runs are to hit the soft bits really.
Admittedly my workout is a bit everywhere at the moment. Hectic life style means it can be hard to stick to a regime (for instance, I'm in Helmand at this very moment). Do I need to factor in cutting periods? I could do with measuring my BFor take some photos to give a better clue of body shape.
A LOT of tuna. Not that it's that bad but I'd try and vary it more. I presume you eat lots more veggies (particularly green ones and leafy ones, but all are good and necessary) and some decent fruits (berries, tomatoes etc...). The quantities look good though, and the variation is ok bar the fact that it's all tuna
Good variation of exercises, but I'm split on whether you should do the cardio after/before your workout. Ideally on a separate day, but if time is short.... I'd probably edge with after, but I need to cogitate over it a little further. I'd put aside the 100 situps, but do introduce core work, but do things like DB pull ins, leg raises to add variety. If you are keen on sit ups though, try alternating them or doing slightly different movements.
Being a little softer in the soft areas isn't too bad, as with a decent regimen and some good lifting it's easy enough to harden up - but I may suggest doing 4x8 to add a bit more volume perhaps.
Don't worry about cutting/bulking, train hard, eat well and just monitor your progress that way. It might be best to wait till you have a bit more stability in your life, and I guess out there you're probably not really able to train or live a "normal" life.
Take care out there and look after yourself - stay safe.
