Re: Pinky screen
I have found like other people that max brightness makes it just about normal, but anything less adds a pinky tint. What to do?
If you think its a problem then ask for a replacement.
How long should I charge my Desire before turning it on and using it?
I'm guessing if you load a non-default ROM you void warranty?
You void the software warranty. Some people claim that you can put the software back the way it was without any trace of it.
The hardware warranty should be intact, but this depends on the company as some are reluctant to acknowledge this.
Yup this is what i would do...hopefully mine wont have the pinky screen...if it does then its going back till i get one that doesnt suffer from the pinky screen...although ill see how i get on with it ie if its a problem for me or not.
I think ill see if it develops for a few days then if no change ill send it back.
If it's part of the technology then every replacement will have it![]()
Just get the phone and enjoy it rather than trying to pick out faults to intentionally **** you off. If this wasn't mentioned on the internet then 90% of people wouldn't notice it and if they did, they really wouldn't care about something soo minor.
*Will eat my words if I get a pinky one and moan like a cheap whore*
Sorry to go on about this but the more I use the phone the less I notice it.
