Seems to be Crossfire issues. No problems here so far. Initially I thought the card stayed at 400/1125 clocks but it went back to the idle clocks after a while. Also I'm not sure about this but I think idle voltages have increased a little.
dowwnload the drivers and installed no problem....but now my idle speed is 400mhz from 157 and idle temps is now 52 from 38....whats that all about....anyway of changing them...cant see it any where
Set default clocks and they should go down.
My dual monitor setup has stopped working since I installed these. Secondary (VGA) monitor is working, but my primary (DVI) has ceased to display anything but a signal not found message.
Havent seen any way to resolve this, guess its time to roll back to 10.4 (I used Driver Cleaner and removed anything with ATI in it before installing)
I'm unfamiliar with this problem, could you elaborate?Well the idle clocks are still high when overclocking so it looks like it is here to stay.
If you don't overclock idle will be 157/300, if you tick the overdrive box your idle clocks will increase to 400/1200.
Best way is to set a overclocked profile with Afterburner and enable it when you want to game, the rest of the time you can have 157/300 clocks![]()
I was told to restart after the install.
Yeah that's what I have done, 2D profile and a 3D one, still a clumsy fix form ATI IMO.
what you say can be done with afterburner.
ATI Catalyst 10.6 delivers official support for OpenGL 4.0 on the ATI radeon™ HD 5000 Series
