- 12 May 2007
- Bristol
Yeah, I don't think it has PB enabled in the beta and as it's the Frostbite engine, I would guess there wasn't much modification involved with getting BFBC2 hacks to work.
Really? From what I've played I'd say the majority of my deaths have been from snipers, and it doesn't help that you're trying to pick people off with ironsights and they're running around with scopes. Game is pretty much everything I hate about modern FPS design.its really fast paced without all the noobtubing or sniper fests of most common fps
Can you pre order it on EA, get the key and just cancel the order? Do they charge straight away?
Nope, people sitting the other side of the map sniping people. Camping will be more of a problem in this game than BC2, especially with stupid kill streaks.The main difference with the sniper class in MoH compared to the other games out is you can actually fire the recon rifles off the hip effectively at close range, hence what you've probably experienced.
Just played this for the first time, and my god it's better than BC2. Got 12/5 on the map, top of my teams list, and 3 different awards.
whats the graphics like ?
Looks the same as BC2.
Can't say really because i'm stuck with 1280 resolution, can't seem to change it.
Seems to be pretty mixed opinions so the only way to know is if you give it a go. Preorder it to get in the beta and if you don't like it, cancel.In your opinions, is MoH worth getting?
