My desire has slcd disapointing![]()
Serious? I think slcd is great certainly no worse than my mates amelod screen.
does anyone know how to view the amount of time you've been out of signal/service?
I saw this once on my phone but can't remember where.
I keep dropping service at work but want to see how bad it really is.
Which ROM have you "upgraded" to?
From the sounds of things, you're using the stock FroYo AP2SD which does have problems. I.e. most applications can't officially be moved to the SDCard and you'll lose any widgets that are on the SDCard when you reboot the phone.
ahh haa.. yes, it looks like that's the case... not with the stock froyo as i used Nextsense, but i did know what i was doing with the ext 2,3,4 business on the sd card and so i don't believe i've got apps2sd+ working and i'm just using the aps2sd in the Settings -> Applications -> Manage section of the phone. Is there an easy way around this?
despite this problem, with a little playing today, i think it is a bit smoother and snappier. i can't say much for the battery life atm as i'm always on it so its taking a bit of a battering. Just having a look at the flash stuff. also, the available memory on my handheld, i assume with this aps2sd thing there's still a fair bit of info stored on the phone, as it doesn't seem to take all of it off the device when you install to SD, is that right?
B@
oh christ, really? :/ Do you know whether there is likely to be a fix for aps2sd anytime soon?Best method would be:
- Since you have root, backup your settings with Titanium Backup
- Backup your SDCard to your PC <-- Important, as your SDCard will be wiped when you partition later.
- Download ROM manager from the Market
- Go into ROM manager and partition the SDCard - SWAP: 0, EXT: 512.
- Go into recovery, wipe data, wipe cache (don't worry, your backup will restore everything).
- Flash NextSense.zip again
- Reboot
- Copy the SDCard backup you made in step 2 back onto your SDCard
- Run Titanium Backup, it will reinstall your applications and their settings.
RE: Phone memory, yes some data needs to be kept on the phone but obviously the rate at which your internal storage will go down, will slow considerably.
Only reason i say is that when i run the restore of my backup (from MyBackup Pro) there's more programs installed on the SD than can physically fit in the phone memory so last time i had to install some, wait for it to run out of space, re-boot then move to sd and repeat. Is this still going to be an issue with Titanium backup or as they are now installed to SD will they go to aps2sd/aps2sd+ by default?
B@
Just had my AMOLED Desire swapped as it was faulty. Now got an SLCD one. No real difference to me. The SLCD appears to be a bit crisper/sharper to my eyes.
so, what's peoples flavour of the month in roms then? 2.2, sense
i'm on neophytes 1.6 at the mo (tried 1.7 but had probs.)
i'm debating whether to try a random rom off xda, or pauls R8 off modaco
Latest Leedroid + Espresso theme, I was on Pinky for a few days until I got lost somewhere and discovered i couldn't get a GPS fix in any app, FAIL!
