- 15 Mar 2010
- Bucks
if im on leedroid 1.8 can you get to 2.0 without having to format? clear caches etc - i cant be arsed to lose everything again but wouldnt mind the new update hes done.
What is Angry Birds??
Take it that Angry Birds coming out tomorrow is old news then?
Just downloaded the SwiFTP app and it lets you see every file on the phone even internal memory, is it safe to delete apps from the app folder that I don't want?
I had a similar problem, I just couldn't get it to go down the correct APN no matter what I tried. It always seemed to default to wap.o2.co.uk for MMS unless I removed that entry totally (I snooped the traffic to observe this). Of course then I could send MMS but my wap wasn't working. In the end I installed LeeDroid and this fixed the issue, I think there is something buggy with the 'APN type' field as setting this to 'mms' for the mms APN entry should send all that traffic down there but it doesn't seem to with some ROMs.
