Nowt wrong with the SLCD models
My phone seems to be now fuzzing on a call, changing the volume doesn't seem to make it better. Should I talk to HTC about this or just go back to T-Mobile? Had mine since April, rather not trade it for an SLCD?
If you have Home Insurance then it might be covered under that.
ALSO: what does everyone use to format the sd card to ex3?
I've had a search on Google and the forums for this, but can't find anything. I'm surprised it hasn't come up before, so apologies if it has.
I'm just wondering if it would be possible to use the Wi-Fi hotspot feature in 2.2 to extend the range of my home wireless network. I've got a computer some distance from my router which is a bit dodgy on connection sometimes.
Could I put the phone somewhere in between them, turn on the wi-fi hotspot, and have the computer connect to the phone? The key bit would then be the phone connecting to the router and not going 3G. Would this actually work?
(The more simple solution would be to upgrade to Wireless N, I know. But I'm just intrigued).
i might be wrong but your pc connecting to your phone will operate on 3g surely? or if the phone is connected to your wifi, it wont let you make it a hot spot?
I can write a guide if you want but the process today is so simple you might hit yourself with your own palm!
you would think, but i would still **** it up and still hit my head with my palm for that fact
there maybe an app, but i think if your phone is connected to a router wirelessly then that will stop it hot spotting?
