You need to reboot after applying the high res setting. Found some apps look odd though so have gone back!
ResToggle on Android Market, using High Res mode, looks awesome![]()
Theres a setting when you set up your google account on the desire which asks if you want to use googles backup service
which is the best back up solution, as after rooting i spend ages setting up my home screens and apps the way i like, i then try a custom rom, after a while i go back and then spend hours downloading and setting up apps, is there a bit of kit that will take an complete backup snapshot and restore it to the letter... or is that wishful thinking
Where is that setting if you have already setup your account?
I believe you are looking for nandroid backup. Complete snapshot of your entire phone, it can be done in recovery mode.
so if i do a nadroid backup then wipe and chuck a rom on i can come straight back to exactly how i was before?
