- 18 Feb 2009
- Behind you
ive got some of those brackets on a thermaltake case, they're a bit loose with the tooless installation thing on the case, but look great. I might just screw them in anyway, as the tooless clips are bright purple/sick green in an otherwise black/silver case for some crazy reason.
Another thing is they look a bit thin and flimsy, but didnt bend at all when a put some light pressure on them (not that they'll really have much pressure exerted on them anyway)
currently during gaming, the gpu reaches around 70, so it'd be nice to keep it a lot cooler! Mine's a 5850!
