- 12 Feb 2009
- London
What cases are people thinking of getting then? I fancy some sort of expensive looking leather one.
Just the splash/shutdown screen and being network locked, I think...
How do I know if I am on the internet properly? Its running very slow, I can connect to Wifi fine which is fast but how do I know if I am connecting to my o2 data usage when i'm out and about.
Firmware update XWKDF with multiple csc not out. Downloading as we speak.
When you're on data the letter corresponding to your type of connection will display next to your signal bars. Eg. H for HSDPA
You can also see by just disabling your wifi, once you do that it'll default to your data connection and as a result display your type of connection. Alternatively go into settings then phone status, your connection type and signal strength will be displayed there.
Turn off the WiFi and find out?![]()
You what?
Fixed it mate.
It's the software on which the phone runs mate, the OS (Android 2.3.3) modified with Samsung's TW GUI, their optimisations and their bundled applications.
But isn't that what stock Samsung Galaxy S II's have?
(Sorry if I am just being stupid here, but I do not get what you mean)
Streeteh - does yours have face recognition unlock?
mine seems to have it unlocked![]()
