I'd keep that last bit to yourself
Another one to add to the SGS II tally - but you knew that already right?![]()
What case is that?
Sena ultraslim
What case is that?
It's a Vodafone handset, but I've wiped it and got the basic KE7 running. Here's the weird bit: it only happens when I'm on cell-based net. Wifi has nothing like that. Check these stats for example, since my last wipe:Mate said its probably some background sync but 24 mb omg. Is it network branded??
From this page, how do I know which tar file to use?
Also about this yellow triangle issue, does that involve flashing a ROM? I dont want to have to reinstall and re-configure stuff just yet (not until cyanogenmod)
That's it exactlyEdit: fornowagain, just seen your reply sorry. I am in doubt... so will ask... lol, whats cf-root? Is that an original kernal but rooted? Therefore you dont have to use a unsecure kernal followed by the original one after... You just flash... and "cf-root"?
Get yourself a usb jig from the bay for a few quid. Resets the counter and removes the triangle, just plug it in.Also about this yellow triangle issue, does that involve flashing a ROM?
Wifi total usage: 223mb (13.6mb up and 210mb down)
Cell total usage: 240mb (232mb up and 8mb down)
I'm totally convinced that it's the upload which is now the only thing ruining my battery. I've turned off all the auto-sync'ing, but I do allow background downloading.
Actually, rather than wipe, I'm going to remove every app I have downloaded (apart from the monitor) and see what happens.
I use apps to monitor net usage. I used to use NetSentry, but I was just recently alerted to Traffic Counter Extended - great little app.Where do you go to see the stats for cell usage? Also.. how did you turn off all the auto-sync'ing?
Thought I'd better check before Vodafone try to charge me for using data which Im prob not aware off![]()
As for stopping auto-syncing, Menu->Settings->Accounts and sync.
hi
having problems with the battery on my galaxy. if i charge the battery from being completely dead to full charge i can use the phone from 9-6 normal usage and the battery would be at 70%. if i then charge it from 70% to 100 the following day and use it as normal the battery drains quicker and goes from 100 to about 40.
does this mean ive got a faulty battery or phone?
thanks
I thought they had taken the 3gb allowance away from new/upgrading contracts and replaced it with the 500mb limit.
Jesus christ that's the only reason i was going to get it on tmobile! That sucks, i'm not sure what to do now.
Would tmobile still be a good network to go for? I live in London and would like a decent internet signal but i've never had a phone with the internet on it so don't know how much data i would use. Are their any good packages out there for £35 a month or less?
It is a handy little program. I just wish it would identify what was using my data!I'm giving Traffic Counter Extended a try - I like the breakdown of data usage of apps.
