- 5 Sep 2005
- Northern Ireland
18 months - T-Mobile, Free Phone, £30.64 a month. 600 mins 500 texts 500MB internet data. Go up to 24 month and its about £26 quid per month.
What operator do you want to use is the question.
Vodafone £25 month, 24 months , 500 mins, unlimited texts + 500mb internet and free phone is a good one.
http://www.mobilephonesdirect.co.uk/Brands/Samsung/b439/p102926.aspx
i bought this phone (sim free) but i have a problem. i can't call out/receive and can't send/receive sms.
i've tryed a orange sim and a t-mobile sim.but with the t-mobile sim i can connect to the mobile internet..
any ideas
It is a handy little program. I just wish it would identify what was using my data!
the phone was off before i put the sim in...Try rebooting the phone with the SIM in it, just in case you've not done that. I had noticed that by the time that I put my o2 sim into my phone (which was already on) it didn't register until a reboot.
Found out why the keyboard didnt sit well with me, its was way bigger to what I was used to! Downloaded this one "hackers" keyboard" which amost perfectly matches what I was using on the N900. Free too, so cant complain.
Not only that, they gave me £30 of gift vouchers to a bunch of different shops, lol
Might have something to do with the amount of emails you're getting? The device is awake when something is pushed or polling is done.
Do want...
Did got!
Well, I want to thank kona786 for recommending chitterchatter, great shop.
I asked if they have a car charger for the phone which they did and they said it's £10, I said ok. Then a few minutes later while I was browsing phones waiting for the paperwork to be completed, they called me over and said they'll give it to me for free. How cool is thatNot only that, they gave me £30 of gift vouchers to a bunch of different shops, lol
Hey I hate to keep an SGS2 from it new owner.
Good times ahead - the phone is awesome.
PS - Are those vouchers coming my way![]()
I have just plugged the phone into my main pc. It finds it ok but I get CDC serial no driver found?
Is there an app that turns off your WIFI, GPS and Bluetooth after a while if it hasnt been used? I used to have one on the N900, Autodisconnect, it done no end of wonders for batterylife.
Random question guys.. (and gals)
Ive noticed my "android OS" eats up most of the power of the battery. I think this is because of my yahoo email app thats on the phone. As i get a lot of emails for work etc. On XDA forums someone said in a thread...
Just wondering if there was a way of setting up how often yahoo email syncs to save the battery? Going off 50-80 times a day is not helping my battery life much![]()
Both of you should check out Juice Defender. It will switch wifi/mobile data off when screen is off but you can set it to reconnect at regular intervals to sync (I have mine set to every 15 minutes).
