Im in a pickle,
Wanna move off my iphone 4 (only had it 4months, cant stand it) but undecided as to which phone to get out of 4,
Sensation
GS2
Nexus S
Lg WP7
I know the Nexus s is old, and spec wise inferior now, but i do like the look of the phone itself, and is a lot more cheaper.
LG WP7 is more of a "id like to try" thing, i gave wp7 a go the first week it was out on a HD7, but got rid of that phone within a week, so didnt have a proper go lol.
As for the sensation/gs2, its tricky, they both have pros/cons (hoping you could give info on whats bad/good bout both there Robbo as you've played with them)
I do a lot of browsing, music, and i do love customising, play the odd game, also looking to play Flash on websites (damn apple) and play films/tv shows from the phone to my tv.
Anyway thanks for any help.
I haven't played with them, I own them
Well, the Sensation and Galaxy S II are the ones you want to be deciding between, the Nexus S and LG Optimus 7 seriously aren't worth bothering with at this stage.
When it comes to the Galaxy S II and Sensation, the simple way to put it is that you should always try and get the Galaxy S II unless there is something about it you don't like. For some it is the build quality, they hate it, I think it's very good and I like it, but the Sensation is a nicer looking phone overall.
As you love customising, you'll get on well enough with TouchWiz on the SGS2, it is functionally very good but some parts of it are ugly, but overall it's fine. You can modify nearly everything about it so it shouldn't be an issue.
Music and media features EASILY goes in favour of the Galaxy S II, though there isn't a big difference in sound quality through the earphones but the loudspeaker is far better and you can root it and modify the sound in more depth. Browsing is similar really, the SGS2 stock browser can be a bit dodgy and the HTC one is nicer, but there are many custom ones.
Games will look better on the SGS2 screen as well, and it will use less power when on. Flash performance on websites is quite a lot better on the SGS2 as well.
Anything more specific, ask away.
oops, thanks buddy, I should have tried that, it was just with the dhd all you did was hold both at the same time. Oh well you live and learn
