How free?
Free as in they had a sign outside saying Free BT Infinity Wifi, i walked in and got a pint, asked about wifi and he gave me the key to it and that was it
Enjoyed my pint and 20 minute Lion download and left a happy man
How free?
Also has the "Expose/show desktop" four finger up gesture made it into Lion?
Sort of, you have to do this three finger and thumb crab motion. Bit like this:
*snip*
I just expect something worth £20, which lion isn't imo.
That's launchpad. You can get to Mission control with a 4 finger swipe. You can customize/enable/disable most of the gestures from the pref pane.
Get a refund then fool and get out of this thread.![]()
Lion (a complete OPERATING SYSTEM) isn't worth £20?I just expect something worth £20, which lion isn't imo.
Do you even hear yourself talk?
Even if it was Vista it would be worth £20! Absolute tool!
As Nonhelmet has pointed out.Lion (a complete OPERATING SYSTEM) isn't worth £20?
Of course its a complete operating system!? lol whatever.. you simply can't turn my opinion around on myself! ha!
So is Windows 7 not a complete operating system over Windows Vista? Sure doesn't look that much more different.
What do you expect it to be? A hologram?.
I guess it looks the same, operates the same because theres no point changing something that isn't broken or doesn't work. Like it or lump it, its a complete operating system if it cost £20 or if it cost £200.
I actually can't believe you can hate a product that is so cheap. Ive spend more money on AngryBirds than I have Lion!
I can tolerate other peoples opinions just fine. I pulled on you because you said you didn't get your £20 quids worth which to me just sounds ludicrious. Again I'm saying this twice. You had Snow Leopard and knew exactly what Lions features were yet you still bought it expecting more? Please explain this to me?
You can run it on core duo's etc
http://forums.macrumors.com/showthread.php?t=1107457
It's not a complete operating system. It's an upgrade to an existing operating system. If you don't accept that, then that's a technical misunderstanding on your part, not a failure of opinion on mine or RoleyBirkin's.
Windows Vista is Windows 6.0. Windows 7 is... Windows 7.0. Snow Leopard is OS X 10.6. Lion is OS X 10.7. Good job picking an example that works against you. You know, I'll throw you a bone here - Windows XP is Windows 5.1. Windows 2000 was Windows 5.0. That any good to you?
Wrong. Windows 7 is Windows 6.1 (technically it's Windows NT 6.1, just like XP is Windows NT 5.1 etc.)
