Uhm, why would you want to put a 2560x1440 native res monitor in 640x480?
Are there any drivers for hazro monitors yet? In screen resolution settings i just have - disply device on: DVI
I cant get dvi to output on post. A vga screen works then switches to the hazro on the login pafe
Wait a second, do you happen to have AMD 5xxx or 6xxx series card?
They have problems with displaying the boot sequence. I think you can get by it by having the monitor off, while booting then turning it on and logging into windows.
Yep, I have a 5770
It worked before I plugged in an Nvidia 480 GTX (that turned out ot be faulty)
It works fine after boot/post up until the login screen
Using a VGA cable and different monitor works
Connecting the faulty Nvidia shows the boot & post screen
See this other thread with other links and info
http://forums.overclockers.co.uk/showthread.php?t=18312971&highlight=username_guest2
I get this too. Right pain in the ass if I want to get into the BIOS as I need another monitor connected. Wish ATI would hurry up and fix this. Weird it only happens with the Hazro though.
Is it with all ATI cards?
Im sure it worked when I first connected it.
Im going to try a standard DVI cable tonight instead of DVI-D
I dont think its an ATI issue because bios and post screens do not use any graphics card drivers. Maybe it is, maybe Hazro should release some monitor drivers
It only happens with ATI cards from what people have reported.
Hazro said it's an AMD problem and AMD told Hazro they're working on a fix. Although it's not a priority really.
I've tried my monitor with only nvidia card so far, but they've been 9600GT, GTX470 and my friends GTX580 and they all worked perfectly.
So in the mean time around 50% of the people with a Hazro dont have a post / boot screen?
It's not all ATI users, it's a minority of them.
Mine does the same with this an XFX 5870. Hazro still state its a problem with most 5xxx series cards and ATI are suppose to be releasing a new firmware, I doubt this will ever show its face.
Hazro are not that bothered, we will be waiting YEARS for this firmware fix from ATI
Mines even worse though, I can plug my hazro in and my machine goes into a constant reboot cycle with no display, If I unplug my Hazro and let windows boot without a monitor it boots fine, THEN I can plug the hazro in and it works fine.!
Talk about crap. I bought my hazro on the first batch of monitors and have been waiting for a fix for months.
