Cruicial M4 0009 Firmware Update
yep, if you run CrystalDiskInfo it will tell you. if it says 0009 then its the latest
Just saw that + I checked the intel icon in the bottom tray. Myn was delivered on Thursday and came with 0002 firmware. Now successfully updated to the 09 one and speeds have improved :-)
HERES MINE
FWIW when I collected my M4 it already had the latest firmware on it. Just one less thing for me to do I suppose.
Just ordered myself the 120gb. Other SSDs were tempting, but this one seems to have a good record of Stabilty :)
just ran intel rapid storage tech and it tells me ive got 0002 firmware.
it was sold advertised as having the 0009 firmware on it.
is it simple to do it yourself?
Hey all,
I've just noticed that in my windows 7 defragment schedule SSD is turned off as expected but it has also disabled my 2 1TB normal drives should I renable these for a weekly check? Also should I set system reserved to be defragmented, not sure if this is on the SSD or not.
Thanks
