- 28 Jul 2011
Anyone know of a mod which i can remove spiders or replace them. I hate them with a passion
Havnt you looked at all the performance reviews yet
http://www.tomshardware.com/reviews/skyrim-performance-benchmark,3074-9.html
Get your CPU overclocked as much as it can, or ideally get rid of it for an I5 2500k.
Fixes bugs:
GRAPHIC: flame from dragons breath, other fire and magix fx invisible, volumetric fog, black dots on the screen or kind of black fence on it, other related to graphics (if you have them). Also it have property to increase quality of shadow texture for reducing "pixelation" (it's not a smooth shadows).
SOUND: stuttering and some unplayed sound (not everyone have such).
PERFORMANCE: this patch not increase performance as framerate (only for some WinXP or very specific systems), but it fix freezing of the game in about 5 seconds when traveling the world. Performance increased for shadow quality "Ultra".
GENERIC: Some users noticed no black screens ar bsod any more.
there is a mod out which adjusts the controller text file to allow you to have up to 7 hotkeys on the xbox controller d-pad now. its out on skyrimnexus. imo the controller works better on skyrim.
Someone said in the offical skyrim thread that there's a mod out for xbox 360 controller to set up to 7 hot keys:
Can anyone give me the link?
Thanks in advance.![]()
This is the one I currently use.
http://www.skyrimnexus.com/downloads/file.php?id=261
Very nice, eight favourites, plus quick save and load.
snip
I dont plan on using many key bindings on joypad but one or two would be nice, the rest of the buttons already are used for useful actions which I wouldn't want to unbind.
snip
Not sure how those figures can be right, I'm only on a Phenom II x3 @3.5GHz with 5850 and my average FPS is practically pinned to 60 (I have the dx9 fps limiter)?
Just found this:
http://www.skyrimnexus.com/downloads/file.php?id=587
Reskin of the ebony mail armor, the modder has done the same for standard ebony armor as well.
Just realised the sunglare mod isn't in the OP, is no one using it? It is fantastic.
