APs are awesome. I have them on my ST. Cant fault them yet but i wish they came with top mounts as well.
Yeah. Bit annoying they don't come with top mounts.
You don't need to take the hub nut off?
Is it different with disks over drums?
Yeah, the disks are much easier. you don't have to touch the hub nut, just remove the 4 bolts which bolt the hub to the beam and it's off.
Drums, like you said, you need to remove the hub nut and drum so you can lineup the hub or something.
I've got Pagid blues on the front with standard disks and they are brilliant IMO. Better than I thought they would be after coming from 8 pots.
Right. Definitely just getting axle spacers then! Was nearly going to just buy hubcentrics out of ease but with only having to remove the disk break that's pretty easy.
must be these:
http://www.eurocarparts.com/ecp/c/F...e12f9780308cdfae4f2e26ff3447d2c772a6b0&000027
A steal at £45 a disk, i paid £77.50 a disk not to long ago but they was made to order when i got mine.
Sad time for meMy ST goes on Friday
I was going to replace it with a cliosport but the cost was too much, maybe another time. Its replacement? a 2011 Zetec S in vison blue
Pics when I pick it up on Friday
Urgh.
Tried to fit my coilovers today and did the rears and got the dampers out of the fronts. Only issue now is that I can't get the top mounts off to swap over.
Going to see if I can take them to a garage and see if they can switch them over to the APs. Mate of mine seems to think they would do that simple task for me?
Genuine top mounts are £30-35 if I recall.
