*****Official Ivybridge Review Thread*****
OcUK bundles seem to support that. They're doing 4.6Ghz, that's a very encouraging figure.
agreed does look encouraging - I think I'll go Ivy rather than Sandy
all these voltages look silly low to me :) I have to use 1.51V (actual - 1.5875 bios) for my Q6600 to run at 3.45 !!
IB is destined to get that reputation. The hive mind has already decided it runs hot, and you can be sure everybody with Sandy Bridge is going to be making themselves feel better about not having Ivy Bridge by telling people with Ivy Bridge that their CPUs suck.
It depends on what you're after... if you want to hit 5Ghz for the fun of it and you don't want to go for a high end waterblock then Sandy Bridge seems to be the right choice. If your mum and dad pay the electricity then all the better.
If you want a moderate overclock then the reviews are overwhelmingly saying IB is the right choice.
In all honesty though I don't see a great deal of difference between SB and IB. There's nuances of flavour between them, but there's no ground shattering differences - and you can see that by the lack of a price hike.
LOL wat?
@ The Halk
Is nothing to do with being a fanboy i enjoy overclocking and when these chips are hitting 90 to 100 temps @ 4.6-4.7 with 1.2 v that just seems a little to hot tbh
@MonsterMoshi
Maybe i should have said ( Why would ( going by the reviews ) anybody who enjoys overclocking go with ib over sb, seems pointless imo )
my bad
@ The Halk
Is nothing to do with being a fanboy i enjoy overclocking and when these chips are hitting 90 to 100 temps @ 4.6-4.7 with 1.2 v that just seems a little to hot tbh , they might be fine running at those temps but imo is just more heat inside the case to get rid of .
@MonsterMoshi
my bad
its less heat to get rid of :)
heat is different than temps remember ...... heat is power output which is different to temps
I'm not keen on high cpu temps though
lol yeah course it is , don't know what i was thinking ( i was'nt clearly ) must have been having a blonde momment .
Ranting & writing = fail :(
Amended
(Gone IB by the way) Given a choice I wouldn't mind the chance to get the heat into and out of the case, less than before though it is, I'd rather a warm heatsink and cool core rather than the other way around - but if that's how it is then so be it.
So, those who are going for the Ivy choice - what cooler are you getting for it? It looks are though it is going to have to be quite a solid one for a 4.5GHz over-clock.
Why not use the cooler which OCUK are using for their overclocked bundles? I assume that they have tested out the coolers which work best with the IB and concluded that the following cooler works best:
Cooler: Prolimatech Megahalems Black CPU Cooler w/ Sharkoon Silent Eagle 2000RPM 120mm Fan
All their overclocked IB bundles are using that.
