Profile 17a
I'm also maxing out at 74/16
Are there any tricks to get full steam ?
		Code:
	# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 31368 Kbps, Downstream rate = 84876 Kbps
Path:   0, Upstream rate = 20000 Kbps, Downstream rate = 79999 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3959)
Medley Phase (Final) Band Plan
       VDSL Port Details       Upstream        Downstream
Attainable Net Data Rate:      31368 kbps         84876 kbps
Actual Aggregate Tx Power:        2.4 dBm          13.6 dBm
  VDSL Band Status        U0      U1      U2      U3      D1      D2      D3
  Line Attenuation(dB):  2.8     14.8    22.0     N/A    8.1     18.8    29.2
Signal Attenuation(dB):  7.7     14.1    21.3     N/A    8.1     18.8    29.2
        SNR Margin(dB):  14.6    15.0    15.0     N/A    7.3     7.3     7.4
         TX Power(dBm): -12.1   -35.4    2.1      N/A    10.9    7.6     7.1
  this was taken after 35 mins up time!
 shortly after saying that i go this:
