you can try with 2133mhz,dram voltage 1.55v and timings of 10-10-10-28-command rate 1t
)strange managed to get the settings 2133mhz,dram voltage 1.55v and timings of 10-10-10-28-command rate 1t booted fine ran prime for 1 hour went to reboot on reboot ram error beeps. Will take a look at this at later date I think. been working at overclocking pc since 9am time for break.
Edit: Little tip if you have razor lycosa you may want a backup keyboard, this motherboard does not like the keyboard.
you should email gigabyte directly or post here(link below) saying your keyboard/mouse incompatibilty,it will get passed onto the gigabyte bios engineers and they can include it into newer beta bios's,they are pretty quick in responding,saves going out to buy new keyboards ect,its just a bios compatibility problem that can be easily fixed
you can post here or email gigabyte.uk directly
http://forums.tweaktown.com/gigabyte/28441-gigabyte-latest-beta-bios.html
be sure to test with both usb3 and usb2 ports and use the very latest drivers for usb3 as older ones were causing problems
Not had a crash since using 100.1 BCLK, but yes the BIOS notes mentioned compatibility fixes.
I updated BIOS to the latest beta last night and it was stable for an evening so I might try BCLK on AUTO tonight.
