Ok, lets makes this clear - it's no RGB Stripe. And will still have the fuzzy characteristic of Pentile up close.
Why do you believe that?
The "fuzzy" characteristic of Pentile comes from needing two adjacent pixels to display points which would, with an RGB screen, use only one. This reduces the definition of sharp changes in colour or brightness.
... The article you linked to gives a nice example: Single-pixel width text, which would be the most 'dramatic' difference between an RGB and a Pentile sub-pixel arrangement.
An RGB arrangement uses a single line of pixels, whereas Pentile smears the text over multiple pixels.
This "blue-dominated" sub-pixel arrangement is what you can expect from RGB OLED screens to come (for the reasons outlined two posts up; that larger blue subpixels are required to maintain colour accuracy over time). The exact arrangement may vary, but the uniform sub-pixel "RGB-stripe" is unlikely to feature heavily for the future. Such designs lead to the loss of blue intensity over time.
