If you used something like Apex Launcher, you wouldn't need the app![]()
Yeah yeah...I know.
Is it just mine or is the file transfer over USB very very slow?
I thought it might be the drivers so installed them from the Asus website. That just made the device unrecognisable via mtp so had to roll them back.
It took an absolute age to transfer my calibre library over. My HTC One X is 3-4 times faster transferring the same files.
So what does this update actually give me?
And does the landscape mode rotate the lock screen too?
The nexus 7 is quite well known for having very slow internal I/O so I wouldn't worry. Annoying but perfectly normal!
Now where's my ota update •taps fingers•
to get mine, i had to force stop the google framework app, clear the data and then check for the update. worked 1st time.
Thanks, that worked for me.
Just tried to run the OTA update on my Nexus 7, and it failed. My device is rooted which I guess is the reason why. I have Clockwork Recovery installed, so can I download the 4.1.2 update from somewhere, and then use Clockwork to install it manually??
I'm taking mine abroad next week so need a case, as I haven't dared take it out of the house yet.
There doesn't seem to be a typical case that everyones buying, so I'm after a few opinions.
I don't want anything too bulky, so no slots for cards or pieces of paper, not essential to have a stand but would be nice. I'm wondering if the Official Nexus one would be best?
