Is there any way to change the default apps the s pen uses? Like when using the gestures, is there any way to choose what email client, sms client and browser it uses?
Random question of the day:
Will installing a custom ROM lose me my s-pen stuff?
Only if you install an AOSP ROM. Flashing a Samsung based ROM like WanamLite will keep all the SPen stuff.
I've had the 4.1.2 update for a few days now and battery life is appalling. My handset is the BTU unlocked version which means i waited for what seems like forever to get the official update.
I have checked my wakelocks using BBS and these are not a problem at all. My phone is in deep sleep mode for at least 94% of an 8 hour night as i have removed a few apps. Despite this, the drain is running at 2% per hour when the screen is off. I've lost anywhere between 16-20% each night since updating. 4.1.1 would drain the battery by 4-5% at most. The Android system seems to be the biggest culprit when checking the stock battery monitor.
I would simply revert back to 4.1.1 but i have now discovered (thanks to the eMMC app) that my handset uses the dodgy chip which is susceptible to SDS. Everything i have read on places such as XDA says to stick with 4.1.2 as 4.1.1 and others without this SDS fix will eventually lead to a paper weight after a number of months.![]()
Right fed up with trying to mess around with my SanDisk class 10 ultra card, made sure I bought it from a reputable place which was direct from Amazon tried re formatting it but it still unplugs every time it comes out of hibernation, it's just irritating now.
Bought a Samsung class 6 from Amazon and seems to be working fine.
Don't anyone buy class 10 cards for the Note 2
My SanDisc 64GB class 10 works fine.
My battery drops 1% every 3-4 hours idle or so on 4.1.2, that's with Google sync on and data.
Jesus, do you run LinPack while idle or something?.
6 hours screen on over a day seems pretty average, I got over 7 the day I first got it since I wasn't streaming 720p for hours.
You get 3 hours of screen on Cas?.
Mike, you can update to the latest firmware using Odin (I'd recommend this over using Kies anyway).
You can find all the latest firmwares on sammobile.com, just search for N7100 or N7105 depending on whether you the 3g or LTE version.
On my phone atm, but if you still need a hand with Odin/firmware later on I'll get all the links for you.
